mike-uswest's avatar
mike-uswest
Explorer III
Apr 20, 2020
Prodigy Brake Control ?
I have a Prodigy brake control on my truck and having a problem with it. I tried calling the company to ask some questions and they won't talk to you if you don't have the prof of purchase. I have had it probably 15 years, so there is no way. When towing my travel trailer it seems to work fine. When I attach the 7 way plug the light comes on showing the C that it is hooked up on the unit under the dash, and the numbers come up when applying the brake showing the level of brake application. I also have a large work trailer that has always worked before, but I was hauling some material yesterday, and there was no response on the control when the plug was attached. I had never tested it before, but when I checked the pin in the plug it did not show any charge coming back to the plug on the truck 7 way when I had my wife pull the lever on. I went back and hooked it up to the travel trailer and it is still working fine on it. The wires look fine in the work trailer 7 way plug, and back to the brakes at the wheels. Shouldn't there be a charge at the truck pin in the 7 way plug when the brakes are applied? I'm just trying to figure out how this works and where to go to get this working again. Thanks.
Mike
  • Thanks for the answers, what is there about the P3 that makes it better? If I go back to another P2, it is a 5 minute job to take one out and put the new one in. It has worked fine for years.
    Mike
    Mike
    Sorry to hear about your Prodigy brake controller, but I would not give up. I had a Prodigy P3 that started throwing a PL code. I contacted the company through their website and obtain a new controller under warranty. My controller was 10+ years old and I did not have a receipt. I was told to send them a photo of the controller along with the serial number. They sent me a new one with instructions on how to return the old one. They even paid shipping on the return. However, due to the current lock down, I have not had the opportunity to use it. I wish you the best of luck...
  • Ok if it is acting up at 15 years I would simply grab a new P3 and get on with my day.
  • Take a picture of the receipt...as many receipts are printed on thermo paper, which fades over time
    I then put the receipt in the manual. Along with writing the date, where, $$, and serial number on the manual
  • The plug on the work trailer looks good, and it really doesn't get that much use. I just watched a video on the Prodigy use, and it said that without the trailer on it when you turn on the key, it should show a NC, then two dots. It used to do that, but it doesn't now. I have noticed that when first starting out with the travel trailer I have been getting some weird messages on the controller, but I would push the brake lever over, and it would straighten up. I did buy it new, so I may have gotten the warranty on it, I can't remember yesterday, let alone what I did 15 years ago. I may just call them and go in as if I had my ducks in a row. Thanks.
    Mike
  • OK the controller does not know what you put in the 7 pin connector. If your RV trailer works, the controller works. I think you have a problem with the construction trailer.
  • The " they won't talk to you if you don't have the prof of purchase." comment I do find interesting.
    I called them when my trailer magnet was buzzing without touching anything, no warranty or proof of purchase. They were VERY helpful and said to unplug the unit for a few seconds and re plug. I did so and all was well.
    I would give this a try just for CHITZ N Giggles.
  • jdc1's avatar
    jdc1
    Explorer II
    Does that work trailer have a battery that needs to be charged? If it's just the brake-away battery, is it wired to be charged?
    If you do have a battery on that work trailer, it may be a simple prong connection problem. The prongs tend to loosen up over the years on the plug. I had to replace the one on my fifth wheel because it was just wore out.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
