GordonThree
Jan 09, 2017Explorer
DarkSkySeeker wrote:
Do propane generators suffer from the same problems as gasoline ones, namely the dried up laquer problem in the carb and jets?
Isn't it a no brainer to have a propane generator since then you share the fuel with the fridge, stove, and heater?
From what I've read, they don't have stale-fuel or carb gumming issues common to liquid fueled generators.
As far as a no brainer? I guess that depends on the hassle level you're willing to put up with.
It's been my experience over the short 30,000 miles I've RV'd, that propane ALWAYS costs more than gasoline and it's harder to find. Lots of places selling 3/4 full trade-in tanks, but few actually willing to pump LP into your tanks.
LP is far less energy dense, so for any given input you get less output compared to gasoline.
My generators are heavy enough, without having to lug around an external steel fuel tank as well. A rubber gas hose is going to dry out under the sun and eventually start leaking. I guess the generator's fuel tank will do the same eventually.
My generator fuel is also "emergency" fuel for my truck. If I should miscalculate a refueling stop, I can empty the six gallon generator fuel can into the truck and go another hundred miles.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
