jplante4
Jan 09, 2017Explorer II
No gumming up (caused by additives the government requires in gasoline), but the regulator can ice up. This is less likely on the liquid side on the regulator which is what the gen runs on. Mine starts up every time when I go once a month to exercise it over the winter.
I personally like the propane Onan in the Sahara, but then I don't run it a lot or for very long. Newer coaches with diesel engines, diesel fired Aqua-hot heaters and diesel generators run off the same fuel, and using a residential fridge completely removes propane from the coach.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
