time2roll
Jan 09, 2017Nomad
A couple 30# bottles will run the fridge, furnace, stove, water for an extended period.
If you plan to run the air conditioner 24/7 you may want to increase your propane supply. But then if you are worried about carburetor gum you may not be using it that much.
And I suppose the furnace does burn some serious propane as temperatures dip well below freezing.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
