Bionic_Man
Jan 09, 2017Explorer
What type of generator? Built in, or portable?
If built in, what type of RV? Class A/B/C, or towable?
How will you use the generator?
What I would suggest for a generator fuel source greatly depends on the answers to the above questions.
To cut to the chase, the only area I might prefer propane is in a towable. Portable generator I would definitely want gas. A RV with a motor, I would prefer the fuel source that the motor runs on.
Even with a towable, I am not sure that the propane is the way to go (and I have a built in propane powered Honda in my 5th wheel. For little stuff like charging batteries, using the microwave, hair dryer, toaster, etc. propane is fine. But when I go and boondock and need to run the air conditioning, it just uses too much fuel. I think it would be much easier to fill with a 5 gallon gas can than to switch out the propane bottles.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
