bendicon wrote:
Thinking about fabricating a spare tire rod that I can connect one end to the frame and the other end to the drag link there by keeping the steering absolutely rigid with the wheels facing straight. It would be easier to attach a tie rod than to remove the drive shaft.
what do you think?
If your vehicle has a steering damper, why not fabricate a solid rod to replace it? You could even make it out of a large turnbuckle, so it would be adjustable.
Anyway, yes, I think your idea has merit. If it is designed to be easy and simple to install and remove, patent it and put it on the market!
