mr__ed's avatar
mr__ed
Roof Vents Open or Closed When Running A/C?
I very rarely run A/C since I spend most of my time in the dry southwest. Now that I'm located in Arkansas where temps and humidity are high I find that I'm running my A/C almost daily . My common sense tells me to leave the roof vents open at least a little to allow hot air to escape since the cooler air will remain at lower levels. However, in experimentation it seems to work a little better with them closed. What about you? Vents closed or open?
