lawrosa
Mar 23, 2018Explorer
Just a note. I added all washers to mine. I also have a 740lb TW @ 14% though. I think for you to restore that weight you may need them all.
Your 120 lbs off but it depends.
How many are in there now?
This is them removing washers from the EQ hitch.. You certainly need to add.
https://www.youtube.com/watch?v=ymcB2yeZr4s
Also what tires you running and whats the weight rating on the side wall?????
Tires are the biggest issue at this point as you are at your axle rate. If the tires are p rated you must derate the side wall rating.
Post those pecs, tire brand, max cold pressure , and weight rating on side wall..
If they are 44 psi tires I would be running full psi to reduce heat. Adding air does not increase weight rating unless they are LT tires...
You may want to consider a LT tire upgrade.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
