tbolt2000's avatar
tbolt2000
Set Up WD Level?
I set up the WD for the new TV had to get a new shank to drop the head down. I followed the instructions and the measurement for the front fender measurement went from 35' to 35 1/4" the rear went from 37 1/4" to 37". Instructions said the measurement should be about 1/2 to 1" difference from the starting point.
Looking visual at the trailer it looks (appears) to still be jacked up in the front. When TT is connected to the WD I put a 6' level on the TT floor and it shows level. It also shows level when the level is placed on the roof.
The spring bars on WD are parallel to the ground.
Is it level? I think so based on the level on the camper floor and the 1/4" difference in the wheel measurments.
Have not weighed it yet want to get close to level before getting axle weights.
Look Level? or looks can be deceiving based on the level and wheel measurements.Thanks in advance!
I can not drop the head down any more. etrail suggested the shank based on the measurements of the coupler being level and the difference of the receiver on the TT height before
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
