- GordonThreeExplorerIs it an extra horizontal row, which wouldn't be much, or an extra vertical row, as in, a double or triple thick radiator? An extra vertical row could double the btu / kwh rating of the radiator?
- acritzerExplorer II
time2roll wrote:
Yes the larger radiator is the prime component in cooling your drive train.
I have the two row max towing radiator in my F150 that only came on the 7700HD version not in SuperCrew back then. But due to a misprint in the oem brochure Ford was required to retrofit as part of a settlement. When I am full throttle climbing in 115 heat the temp gauge just barely moves. If I had the original radiator I am sure I would have had to throttle back plenty of times. The original radiator had just one row.
Larger radiator takes the pressure off the other coolers to supplement.
I see. Based on the description above of the super cooling radiator only have one additional row...is that a significant size increase?
And a follow up. Are there aftermarket heavy duty radiators that could possibly be used? - Yes the larger radiator is the prime component in cooling your drive train.
Larger radiator takes the pressure off the other coolers to supplement. - acritzerExplorer II
Hank85713 wrote:
You dont say for what vehicle but YES as a needed item. Some chebbys have heating problems (older ones), some fords have heating problems due to bad water pump impellors, dodges?
Anyhow the radiator cools the engine and that is the most important other than a large cooler for the trans.
Did you ADD all the other stuff after the fact or did the vehicle just not come with the larger radiator?
Yes, we added a transmission cooler, 7 pin wiring, brake controller. It came with a class IV hitch. - acritzerExplorer IISuper Cooling is a Ford term. A guy from an Expedition forum says "Ford's HD tow package on your 2011 included a higher capacity radiator. One extra row I believe. Fords calls them "super cooling".
I don't really know what that means, but "one extra row" doesn't sound like a huge difference to me. - Hank85713ExplorerYou dont say for what vehicle but YES as a needed item. Some chebbys have heating problems (older ones), some fords have heating problems due to bad water pump impellors, dodges?
Did you ADD all the other stuff after the fact or did the vehicle just not come with the larger radiator? - GordonThreeExplorerNever heard the term myself. I've heard of the hd towing package, which usually means a trans cooler and sometimes an engine oil cooler.
What manufacturer is offering "super cooling?"
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
