jeshoffstall's avatar
jeshoffstall
Thoughts on my scale numbers?
Finally got around to finding and using a CAT scale on our way to a campground.
Packed as normal for a four day weekend. Wife myself, two bikes and a small tote of firewood.
Camper is a Flagstaff V lite 21WRS
Dry Hitch Weight 597 lbs. (271 kg)
Unloaded Vehicle Weight 4,991 lbs. (2,264 kg)
GVWR 6,550 lbs. (2,971 kg)
Cargo Carrying Capacity 1,559 lbs. (707 kg)
Exterior Length 24' 7" (7.5 m)
Truck is a 2010 Toyota Tundra 5.7, 4x4 with towing package
GVWR 7100
GAWR FT 4000
GAWR RR 4150
Payload 1380
Truck without trailer
Steer axle. 3500
Drive axle 2740
Gross weight 6240
Truck w/trailer WDH bars not engaged
Steer axle 3080
Drive axle 3700
Trailer axle 5080
Gross weight 11,860
Truck w/trailer, WDH bars engaged
Steer axle 3280
Drive axle 3400
Trailer axle 5180
Gross weight. 11,860
I am using an equalizer 4 point hitch (set up by dealer). The bars are parallel to the frame and my toung is about 1-2 inches lower. I have five spacer washers on the hitch head.
It appears I need to get another 200 lbs on the steer axle? Do I need to add/remove washers or raise my bracket another hole? I just do not want to over correct.
Thanks for any insight you may have!
Jack
