brianosaur's avatar
brianosaur
Explorer II
Mar 27, 2018
Tires sitting on composite decking?
Just finished laying down my uncovered outdoor gravel parking pad.
(3/4" Bluestone with smaller fines in it)
I was going to put down a few plywood strips and get some rubber mats to keep the tires on.
Then I thought what about composite or pvc deck boards?
They shouldn't retain moisture or ever rot.
However, I read some folks like the rubber b/c it gives a bit of softness under the tires and may help prevent flat spot memory.
What do you think?
  • downtheroad wrote:
    A good bed of gravel (like you have) should be good enough.. Should drain and prevent standing water.
    If want you can also use a Lynx Leveler under each tire to get them up some off the gravel...Lynx won't rot or retain water...probably better than composite (Trex like) boards....
    Okay good idea.
    So the big no-no about parking on concrete, that's different from gravel, is moisture? I thought it was some weird chemical reaction thing between rubber tires and both concrete/asphalt.
  • A good bed of gravel (like you have) should be good enough.. Should drain and prevent standing water.
  • 2oldman wrote:
    Modern tires don't flat spot.
    Tell that to the internet
