dbs944
Jun 06, 2013Explorer
TOAD Wiring
This is kicking my butt.
I've had the Blue Ox lighting kit installed in my CRV. I've also replaced the 7 pin connector (thinking the old one was the problem) on the MoHo and have a new connecting cable.
I can't get the lights on the toad to work properly so I've gone through the wiring, reconnecting everything. Here's what is happening
Tail lights - apparently work fine
Signals - either left or right flashes both
Tail + signals - both sides solid.
Brakes - nothing - I've installed the Hoppy for separate brake circuit but can't get the rest working so haven't messed much with the brake lights.
Checking current before the exterior plug, with the lights on, I'm getting 12 volts across the brown wire. However, I'm also getting about 1/4 - 1/2 volt across the yellow and green turn signal wires.
When I check voltage at the 7 pin connector at the rear of the Moho, I'm getting 12 volts accross all three of the pins.
Is my problem the 1/4 volt leakage or is this normal?
I'm pulling out whatever remaining hair I have.
Assistance / advice would be greatly appreciated.
Dave
Dave
Moved to Dinghy Towing forum from DIY.
