lbrjet
Mar 31, 2014Explorer
None of that 900lbs is going to the front axle. Put 900 lbs on the back end and that levers weight off of the front end. The WDH puts back some or all of this weight if it is set up correctly. However, 15-20% of the TW will be moved to the trailer axles. Add the weight of the WDH itself to the rear end and you are still going to end up with close to 900lbs on the rear end of the truck. Maybe more if all the front end weight is not moved back to the front.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
