- AlmotExplorer III
MEXICOWANDERER wrote:
Nineteen years...I have three mounted in Quicksilver and two in la casita.
Yeah, if you have room to mount 2 or 3 of them.
19 years ago LG wasn't a bad brand, probably still made in the same place where they designed it.
Now, with 2 billion people cobbling up God knows what there, you never know what you are going to get. Climatrightair - who are they?
Here is another 12000 mini-split, at least with Panasonic compressor. A bit cheaper than Climatright. One thing I can't understand is how it can draw 16A @ 1400W. Shouldn't it be 11.7A? - MEXICOWANDERERExplorerI use nothing but 11 or 12 EER units and they work great and accumulate enough moisture outside to feed a small plot of cantaloupe. I purchased the precursor to LG (Lucky Goldstar) in 1997, new units at Fry's electronics. A friend and I purchased an entire pallet of 5K units for $39.95 each. New, not refurbished, not seconds...that's not likely to ever come around again. NONE and I mean ZERO units of the 24 have malfunctioned. my friend turns his on in June and off in November. Nineteen years...I have three mounted in Quicksilver and two in la casita.
- JiminDenverExplorer IIompared to my 5000 BTU window shaker, these are double the watts or close to it. Mine uses as much as the 2500 BTU model here.
- MEXICOWANDERERExplorerCover up in a good thick blanket, then grab the hose and stick it in.
I love that EER rating. Reminds of of fuel saving garbage "You'll Save So Much Fuel You'll Need To Hang A Bucket Beneath The Gasoline Filler Cap!" - joloooteExplorerThe old saying ... " When a little is good ...A LOT ain't better".
- Chris_BryantExplorer IIThat split unit looks pretty good- 12k btu/hr for 1241 watts, plus variable btu- draws 11.3 amps on max.
- pianotunaNomad IIIWell that's what I get for not clicking on the specficiations myself. (i.e. someone sent me this via email). I guess the 482 watts is for the dog house unit. Sorry to raise everyone's hopes.
They do have a split unit which is heat pump style, but of course is even more watts. - gboppExplorer
Chris Bryant wrote:
Not sure where you got the 492 figure- the specs I saw list 1290 watts for the 10k btu/hr unit- the 480 watt unit is 2.5k btu/hr- not really big enough for much more than a doghouse (not big enough for that in Florida :) )
X2. I was looking but, didn't see anything about 10,000 BTU @ 492 watts.
If it sounds too good to be true........ - MEXICOWANDERERExplorerSpec Clip Spit & Splat
Unit Weight (lbs.) 60.0000
Cooling BTU 12000
Heating BTU 14000
Volts 115V
Cooling Watts 1241
Cooling Amps (Operating) 11.3
Heating Watts 1780
Heating Amps (Operating) 16.2
Cooling Capacity (Room Enclosure Size) * Up to approximately 4,000 cu. ft. (LxWxH
Dehumidifying (pts./hr) 1.25
Thermostat Digital, Indoor Unit
Control Panel Features Mode, Fan Speed, Oscillation, Timer, Temperature
Remote Control Features Mode, Fan Speed, Oscillation, Timer, Temperature
Case Dimension (Boxed) Interior Unit: 34.5" × 16.1" × 13.9" Exterior Unit: 36.2" × 13.2" × 24.4"
Unit Dimensions Interior Unit: 31.5" × 11.0" × 7.5" Exterior Unit: 32" × 10.1" × 21.3"
Unit Weight (lbs) Interior Unit: 30.86 Exterior Unit: 70.55
Shipping Weight (lbs.) Interior Unit: 35.25 Exterior Unit: 74.96
Assembly Quick Connect Pre-Charged Hoses
Refrigerant R410a
Air Filter Yes. (cleanable, non replacement)
CFM (max) 323
Noise Interior Unit: 42 dB Exterior Unit: 53 dB
Recommended Generator Inverter, 2,000W Minimum
Warrantied Outside Temperature Range Less Than 110°F, Over 40°F (heat pump)
Recommended Use Garages, Sheds, Cabins, Tents, Greenhouses, Room Additions, Sunrooms, Apartments and Condos, Tiny H
Traditional heat pump aka Oil of Snake. Look at the stupid condensing liquid measurement. My 5,000 BTU window unit will dehumidify better than this. Impossible to cool air without removing humidity. Hissssssss Rattle Rattle - Chris_BryantExplorer IINot sure where you got the 492 figure- the specs I saw list 1290 watts for the 10k btu/hr unit- the 480 watt unit is 2.5k btu/hr- not really big enough for much more than a doghouse (not big enough for that in Florida :) )
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
