5thwheeleroldma's avatar
Nov 25, 2016
12 Volt Manual Override Switch
I replaced both batteries in the 5th wheel and when finished, I only get 12 volt power if plugged into 120AC. If unplugged, everything is dead. My owners manual says something about a "12V Manual Override Switch" which protects the fuse block. It says just punch it and should restore 12 volt power.
I can't find the Override Switch. Does anyone know where it might be in a 2008Hitchhiker, an what it looks like? Or is it something else obvious I have overlooked?
  • There may or may no be a disconnect switch. If there is it should be close to the battery, could be on the positive or negative.
    There is for sure a DC breaker, should be near the batteries, follow the positive cable. Might be resettable, if not needs replacing.
    Are you sure you hooked them up correctly? There are 2 30/40 amp fuses on your converter that will blow with reverse polarity.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
