Richard1616's avatar
Richard1616
2000 Monico Diplomat fridge won’t run on propane
My fridge in My 2000 Monico Diplomat won’t run on propane but with generator or shore power it is fine. Any help would be appreciated.
  • It sounds like the original circuit board has bit the dust..  Meaning, there is a main "mother board" in the electronics of that fridge and it has failed after 25 years..
    Consider that a pretty good run.. I bought a new travel trailer in 2019 and the system board was bad from the start..  It would run on both gas and electric while plugged into shore power, but once it reached temp and cycled off, it would not kick back on again and flash the "check" light until reset (turn off and turn back on again)..
    It was not until I unplugged shore power and ran it on gas alone, that it worked normally, but on shore power, no joy..
    Called about the warranty and it was going to be 3 weeks just to get me into the dealer and then they'd have to do that same diag as I just did over the last week and then just say we need to replace the main board... I got one off of Amazon for around $100 (back in 2019) and installed myself and it's been working fine to this day...
    Good luck!  Mitch
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Wow quite the succinct diagnosis with zero information provided by the OP that would lead you to that conclusion…..lol
      • MitchF150's avatar
        MitchF150
        Nomad
        Just a off the cuff thought and some "assumptions" of course.. 😁  We don't know if it works on gas plugged in or not.  That was my thing, but I figured I'd just toss it out there all the same..  Not much traffic on this site it seems from the old "rv.net" days...  I've been idle for a couple of years and just clicked on my bookmark to see if it still worked..  ha, ha..  Still does, so hit a few posts. ha, ha..  Mitch
  • Look either inside the refrigerator doors or inside the outside access panel for a make and model of the refrigerator and post the information here.
    Do other propane fueled appliances work? My refrigerator will not work on Propane after the trailer sits all summer with the gas bottles turned off. To fix this I have to light and run the stove top for a few seconds to purge the air out of the propane lines.
    Turn the refrigerator off and find the outside refrigerator access panel and open it. Possibly by using a small screwdriver and turning the latches 90 degrees. From there what do you see? Have somebody inside the MH flip the refrigerator to gas while you stand outside at the access door. Does anything happen? Any clicking or just silence? Inspect any fuses to make sure they are still good.
    Do you see yellow powder in the outside compartment? This would indicate a refrigerant leak. Yes it's kind of unlikely because the refrigerator still cools on electric, but it's worth knowing the significance of the yellow powder.
  • LOTS of things to check. Like, do you have LP, are you getting a pilot, is your regulator working, all other LP appliances working, bugs in the lp inlet screen, are you getting an error?
