- klutchdustExplorer IIThanks, located the part number Grote 61641 nothing available local so ordered it online.
The one needing replacement was knocked off. Appreciate the feedback guys. - SuperDutyFiverExplorerThe Bargman #78 Series replacement light is a match.
If just the light socket is shot-you can gut the new fixture and replace into the old-that solves the paint issue-if you're adding more lights then you need to address the paint issue. Somewhere you should have a code for what paint your coach has on it-duplicolor has many close matches and I've been able to paint lights well enough to install without issue. - Road_RunnersExplorerWhat I see looks like a pretty standard RV light fixture. I would imagine Monaco purchased that fixture from some supplier. if you have no luck finding a genuine Monaca fixture go to an brick and mortar RV store or an online RV supplier and you will probably find a match for that light.
- klutchdustExplorer IILight and lens
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
