Ekimotirb's avatar
Ekimotirb
Explorer II
Jul 03, 2025
Solved
2024 Holiday Rambler
My 2024 Holiday Rambler, Armada 40M;
Running on generator I mistakenly used the microwave while running the cloths dryer as well as all three A/C’s, resulting in all three units shutting down, I know, I know! Well now not one of them will start back up! I checked the breaker panel and nothing is off? It’s supposed to be pretty warm tomorrow (July 4th in Rhode Island) so any help is very appreciated!
  • Did you check the breakers on the generator itself? likely when you overloaded your generator, it's breakers tripped.
  • how did you check the breakers just look at them or did you use your hand to see which one is a little lose and which ones are tight.  breakers don't flip to the tripped side they just get a little play in the switch and you have to turn it off then back on to reset it.
    • Ekimotirb's avatar
      Ekimotirb
      Explorer II
      It turned out to be the breaker on the generator, right next to the on/off switch!
  • Wow, you should have hooked up an electric smoker and fired up the curling iron and hair dryer too….lol.
    It’s a breaker. You just have to find it.
      Ekimotirb
      Explorer II
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
