PerryB67's avatar
PerryB67
24 V Solar Panel(s)
Rich Solar makes a 200 watt 24 volt solar panel.
I would remove my rear mounted 170 watt 12 v panel and purchase two of these Rich Solar 200 watt panels, with room to add a third if needed. One would be on the front and one on the rear of the camper. The 200 watt can be mounted in the same mounts as the existing 170 watt. I want to run parallel since we will be traveling where shade is often on either the front or rear of the camper.
I have a Victron 100/30 smart controller already for this setup.
Smart move or a waste of money?
Enjoy,
Perry
    Enjoy,
    Perry
    30 watts for an upgrade almost seems like a waist of effort these days with the price of solar panels. look at split cell 24V panels and I would go 325 or 350watts.
    I am running one 325 watt 24V split cell on my camper with a renogy MPPT controler and it out preforms the three 160 watt 12V pannels on a PWM in my 5th wheel, so thoes will be gerring switched out soon.
    if you can chage it out for one 325 or 350 watt then add a second one. then you only running two panels which most people should have room for.
    Steve
    Enjoy,
    Perry
    I really should have said, "Smart move or a waste of my time."
    The money is really meaningless, whereas my time has value.
    SJ-Chris wrote:
    I was going to just put up a 250w system with a used panel on my RV. When I went to pick up the panel, they were on sale for $35 each (this is from a big used solar company in Arizona). To me, that's pretty much free. So even though I didn't need it, I put up two panels for 500w total. I've boondocked several times now and they work great. I'm adding a 3rd lead acid battery making my bank 300AH. It's more than I need and the solar easily keeps everything charged. It's nice never worrying about having enough power....
    Good luck!
    Chris
    I have 260 ah's of SiO2 batteries with 208 useable at 80% DOD. We currently don't have an inverter, nor need one. The question I have for Terry is, "What storage space in the kitchen are you willing to give up for a microwave?" In over 25 years with that question her answer is still, "None!" We do carry a 700 watt toaster though, used when we have hookups, and she'd like a 700 watt hair dryer. We camp off-grid as much as possible, including BLM and stealth camping.
    My other choice is keep the 170 watt panel (19.3 Vmp, 8.8 Imp) and add two 100 watt panels (18.8 VMP, 5.38 Imp). It's a much neater and simpler install. Too often camping in Minnesota (twice last winter though) one end of the camper or the other is in shade (11 days in Big Bend's Cottonwood campground). I would want these panels installed in parallel (roughly 255 watts total, depending on who's math you use), and wonder if I'm splitting hairs with 20 feet of 10 gauge wire from the roof to the controller. 24 volt panels should fix that perceived problem? Or am I making a mountain out of a molehill?
    I'm not sure our Victron 100/30 could handle three 24v panels.
    The two 100 watt panels added is the cheapest. $210 total for both panels, vs $440 for the Rich Solar panels.
    The 100 watt panels can be mounted with VHB tape with no worries, using Renogy tilt mount brackets for the front panel. I would use the same mount(s) with the front 200 watt panel(s) but have a bolt on each side though the fiberglass roof for safety.
    We have no genset, nor wish for one, and don't want to get into a DC to DC charger from the tow. We do have a 100 watt Renogy portable, with three 15' cables, hooked to a separate Victron 100/20 smart controller in the camper, feeding the battery bank. I'm lazy and find managing a portable a PITA, but there are times it will be needed.
    Our battery choice was a no-brainer for us, but this choice is driving me crazy. I would do the installation myself, and, except for time, have the expertise to do the install. It's literally impossible to find a solar installer who knows what he's doing in Minnesota, because of the home solar installs with tax rebates.
    And yes, feel the same as Chris. "It's more than I need and the solar easily keeps everything charged. It's nice never worrying about having enough power...."
    Our battery choice was the first piece, now I need to finish with the solar.
    I'm dyslexic and probably have screwed up something written here or have left something out.
    Enjoy,
    Perry
    Enjoy,
    Perry
    Or search your local craigslist or facebook or nextdoor for something like these...
    https://minneapolis.craigslist.org/ram/grd/d/carlton-310-watt-solar-panels-105-each/7301662326.html
    300w for $120. 600w for just $240. Not sure you need 600w, but just an idea...
    Good luck!
    Chris
    Enjoy,
    Perry
    What does your battery bank look like? (how many AH?)
    What about just adding another 170w panel? Would 340w deliver what you need? (If so, it saves you $200+). Or do you really need 400w (or more)? If you only have 200-250AH of batteries then 340w will likely be enough for most of the time (unless you are camping in shady areas or in bad weather). Do you have a backup generator just in case you need it?
    OR, for likely less money you could buy TWO more 170w panels and then you'd have 3 panels delivering 510w for less price than buying two 200w panels (400w total) and having no use for the existing 170w panel. (I'm assuming the similar 170w panels are a little cheaper than the 200w version).
    -Chris
  • Hi,
    I would go with the three panels if the controller can accept that much energy.
    I find my system starts charging earlier in the day. Input is 33 volts.
