KendallP's avatar
KendallP
3 Group 27s with some wiggle room? Or 4 GC2 Sardines?
EDIT: Regarding Question 2 below, the guys in the first few replies got me thinking I can suppress my OCD and get by adding water with a watering system when I would normally just inspect. If they're full, I'll know it because they won't take any water.
The slide-out battery tray in this motorhome is designed for 3 group 27s. It currently has 2 new ones and a slightly older one that tests almost as new via they hydrometer. The tray can also probably fit 3 29s and maybe 3 31s. All with about 3/4" between them horizontally like so...
______
I_____I
______
I_____I
______
I_____I
The tray will also just fit 4 Deka GC2s in 2 vertical pairs thusly...
___ ___
I....I I....I
I....I I....I
I__I I__I
___ ___
I....I I....I
I....I I....I
I__I I__I
Each pair might have 1/8" of gap between them, left to right. And maybe 1/2" between the top pair and the bottom pair.
Also... the back vent caps are going to be very hard to check and fill without removing the front pair of 64 lb batteries... at chest level. There was a time when I could load an awkward, 120lb 4D in and out of a tight battery compartment solo, no problem, but... I guess I'm gettin' old.
The benefit of the GC2s would be...
1. 460 Ah vs roughly 300
2. Greater deep cycling durability / longevity
3. And easier to recover from progressive sulfation incurred by successive 50-90% charges.
That's if the tray can stomach an extra hundred pounds or so.
Questions:
1. How bad would it be if the 4 Dekas were sandwiched together with no gap between them?
2. How big of a boondocker does one have to be to remove a pair of GC2s every time one needs to check the electrolyte of the other pair? Let alone top them off...
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
