BobsYourUncle's avatar
Sep 11, 2013
4 Blown batteries (pics) How??
OK, these are not exactly RV batteries but a battery is a battery.
These 4 small 12V batteries are in a box, hooked up in series to provide 48 volts to run my wifes Gio electric scooter.
She went to use it yesterday and it would barely power up. She put it on the charger overnight, as she usually does to charge the thing and the next day it still would not go.
My son has one too, so we swapped batteries and all was well. The scooter ran fine.
Then we pulled the battery pack out and removed the lid. This is what we found:
All 4 batteries are severely bulged and melted. Needless to say they are toast. (pardon the unintended pun)
I am wondering what the heck went wrong here.
The charger is a typical little charge box that you plug into the scooter to charge the batteries up. It likely has a sensor to shut off the charge when the batteries are full.
About a year ago, the charger ceased functioning. I took it apart and found that there were 2 connections internally that had broken off. Cheap Chinese junk! I soldered them back on and all was well until this happened.
Any ideas on this?
I am thinking maybe one battery packed it in so the charger wouldn't shut off and severely overcharged them.
Or maybe the charger malfunctioned (cheap Chinese junk) and applied full voltage for too long, thus overheating them.
I haven't tested the charger - I don't really know how I could.... I could check the output and thats about it.
I am amazed they never exploded!
  • beemerphile1 wrote:
    Old age most likely. I replace small AGMs that are split and bulging all the time in emergency light fixtures.
    X2, I see this in UPS's a LOT. Never seen one explode.
  • Well,
    At least two of those shorted a cell. It looks like the most negative one went first. After that, all the batteries were being overcharged. It isn't hard to hurt those little guys.
    The charger may still have been damaged.
    Matt
  • Old age most likely. I replace small AGMs that are split and bulging all the time in emergency light fixtures.
  • I am sure one cell or battery went bad. Have rebuilt at least a dozen of these battery packs in scooters over the years. 4 new batteries are actually pretty cheap depending on which model you have in there. Most are 12V7AH and can be found for under $20.00 each if you look around. I would replace all the jumpers when you replace the batteries. I normally use the next size up wire just because.
  • All it takes is for one cell in one of the batteries to be shorted. When hooked up to a charger the charger then sees a low voltage and just keeps trying harder and harder to bring the entire group up to full charge. This continues until you either unplug them or one of the batteries explodes opening the circuit. Looks like you will be purchasing 4 new batteries.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
