kwinterb's avatar
kwinterb
50 AMP power from a generator?
I need to get 50 AMP power from a generator. I’d prefer to go with a Yamaha Inverter EF6300iSDE for all the typical reasons, which is rated at 45.8 amps /52.5 amps @120V. But of course that’s based on splitting the load between the 30 AMP outlet and the 20 AMP outlet. Based on a lot of research, I’m convinced the common RV Electrical Cheater Box is not going to work. I assume the JTB Power Solution will work. First question, is that a good assumption (I know, I should just call them). But the bigger question is, is this really the only valid solution? We do a fair amount of dry camping in the heat and per the wife, we need to be able to run both AC units. :)
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
