BFL13's avatar
BFL13
Explorer II
May 27, 2015
60 Cell Panel vs 24v Bank MPPT and PWM UPDATE
UPDATE--results with MPPT posted 1 June.
Got a chance to run this test today with no clouds but a slight haze up high so not quite 1000 insolation, showed as 8.93Isc vs rated 9.0, however that did not affect the tests as such. 255w panel tracking aimed at sun.
Started with the 458AH bank disconnected from rig ( it was running on a spare 12v meanwhile) at approx. 75% SOC (very approx.!) at 25.4 volts. panel Voc 35.2, 46C , Isc 7.6
Using the Solar30 PWM controller set to 30.0 volts Vabs:
0845- 25.7v x 7.3a = 188w
0945- 26.5v x 8.1a = 215w
1115- 27.4v x 8.1a = 222w
1215- 28.9v x 7.6a = 220w
1230- 29.5v x 7.2a = 212w
1245- 30.0v x 6.8a = 204w
So yes, a 60 cell panel can get the batts to 30 volts no sweat.
You can see the amps started to taper towards the end with SOC maybe 92% or so. Could be a touch of IV curve drop in I above 28v in there too.
While at it, I swapped over to the Eco-Worthy MPPT with bank at 24v
1115- 27.4v x 8.0 = 219w compares with PWM at 1115 above.
So as with the first test of MPPT vs PWM at 24-24 I did with my old 230w panel, they come out nearly equal for amps to the battery at 45C panel temp.
One new thing I have not figured out yet is that the PWM controller was not passing through the actual panel Isc as taken disconnected, but something less than that. eg, Isc 7.6a, vs 7.3a to battery, and 8.2 vs 8.0 etc. The IV curves don't show that much drop in I so the controller must be eating some. Not sure--needs more study :)
I was hoping with a rated 9.0 Isc, I would get that to the battery with PWM in 24v mode, which would be like 18a in 12v mode, but it looks like this won't quite happen. When I do the hot panel tests this summer, I will check on that some more.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
