cswinford's avatar
cswinford
AC is icing up but not cooling
Hello,
We have a 15k BTU Colman AC with a heat pump in our Open Range fifth wheel. The unit wasn't cooling so I replaced the capacitors, but to no avail. The compressor is running and the lines ice up but it is not blowing cold or even cool air. I've had a mobile Rv tech look at it and he says the unit needs replaced. I thought I'd run it by this group to see if there's anything more I can try before dropping a grand on it.
Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
