drumming102
May 29, 2016Explorer
Adding an inverter off the Distribution block
So, After looking I have a TON of space under my converter/charger on my passport 2920BH.
After looking at the 12v distrobution chart for the fuses it looked like I had quite a few open blocks to tap off of to add a 600W inverter on a short run mounted directly below the converter/charger on the knock out panel.
PIC
Much to my suprise when i took the panel open every block looks wired? Where are these going? are they just spare wires running around? They are not labeled as to what they are going to?
I could just tap into the hot and not in here and add it's own fuse and bypass this panel but I think the install would be cleaner using this panel.
What/where are these spares going to?
PIC
