time2roll
Jul 03, 2020Nomad
The reports I read from people with a residential fridge will generally say there is no problem with two batteries even for camping one night without power. Plugged in or in transit is never an issue. For extended off grid 500+ watts solar is good but not enough to avoid using the generator.
We really need to know more about the expected usage. And I assume you turn the fridge off while stored between adventures. Since you mention generator charging it would help to know what the actual charging voltage is and the hours per day spent charging.
You might find some reports by putting "residential" in the search box.
