MFL's avatar
MFL
Nomad II
May 29, 2014
anode rod threads
The threads in my suburban water tank have gotten kind of corroded. I am putting a new anode rod in, but it will not turn in very far.
The threads are not stripped, but need a good clean out. Does anyone have a good method for doing this?
Is there a thread chaser available, for cleaning up these threads?
Thanks for any ideas,
Jerry
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are two devices that are nearly identical.
    One is called a "Thread chaser"
    The other is a Tap
    The Tap is designed to cut new threads in smooth metal it is thus somewhat more expensive.
    What size: 1/2 inch Iron Pipe Thread.
  • I use a round wire brush to clean mine every year when I check the anode and drain the tank for winter. I think the brush was designed for use when soldering copper pipe.
  • The threads are tapered in, they are pipe threads. It is expected to get tight as you install it. If the threads are clean and sharp, there is no need to chase them. Just snug up the anode, pressure test for leaks, if no leaks let it be, if it leaks, tighten until the leak stops.
  • Yes, you could chase the threads with a tap. You might try to clean the threads with an acid based cleaner like CLR, humidifier cleaner, or water softener cleaner. All of these will dissolve water-borne mineral deposits.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
