biggjb wrote:
I am just curious. The thread for the anode rod in my hot water tank appear to have a build up of something white. The material is very tough and I am not sure how to remove it. It is only on part of threads and does not interfere with the installation of the anode rode. Just curious if anyone else has the problem and if anyone has any suggestion to remove it.
You can run a pipe tap in to cut out the white stuff. If you aren't skilled with a tap, it is easy to cross-thread the hole and do real damage. I've cleaned mine that way. After tapping, flush the hole again.
