Jibba's avatar
Jibba
Atwood RV Furnace keeps tripping 10amp breaker
My Atwood Furnace will turn on, I hear the spark and that ignites the burner. I immediately begin to feel heat come from the exhaust outlet. This runs for 30 seconds, and then the 10amp breaker trips.
I have tried several suggestions I have read on the board already.
Here's what I know:
  • It is not the propane tanks, they are full
  • It is not the propane mixture, I have a solid blue flame on my stovetop.
  • I have reset all the breakers, turned everything off and back on.
  • I have two new batteries. They were installed earlier this week and are holding 13.4 volts running in series.
  • I am plugged into 110V AC, but the same problem occurs if I disconnect and run only off battery.
  • All my other propane appliances work as they are supposed to.
  • I have used my air compressor to blow out the outlet. I have also disconnected the circuits on the board and checked them all. I cleaned them and reattached making sure everything was snug.
It doesn't appear to be a faulty connection, or ground as it is working fine, then tripping the breaker about a minute later.
Could it be the air intake? If so, where do I find that? Is that part of the AC on the roof?
I'm stumped, and short of buying a new circuit board that may not solve the problem, I'm running out of ideas.
Can anyone help?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
