brulaz's avatar
brulaz
Battery Fuse for Solar/Charger System
From the new solar/charger system was planning to run 6ga + and - wires right to the battery terminals, not tied in anywhere to the existing trailer wiring.
Was thinking about using a Blue Sea 5191 Terminal Fuse Block & Fuse right at the + battery terminal (in addition to the breaker & internal protections at the other end of the wire). Fuse Block
I think the existing trailer wiring has a fuse about 4' from the battery just inside the trailer in its floor space. Although that space is very well protected and dry, it would be difficult for me to route my new 6ga wires to it.
My battery boxes are just the standard, outside, plastic ones. Am hoping that with regular terminal cleaning, the 5191 Fuse Block at the batteries will work ok.
Any experience out there with a similar setup? Thoughts? I'm assuming that the closer to the battery the better ...
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
