- There are two different types of tool and rings. Most do it yourself guys buy the cinch ring tool. Cheaper and works on all sizes. The crimp rings/tool are more expensive and you need a different tool or adapter for each size.
Sharkbite type of fittings work but if you use it often the tool and cinch rings are the way to go. - Old-BiscuitExplorer III
enblethen wrote:
I would not use crimps. I have previously used push type fittings in both plastic version and brass. I liked the plastic ones better. Here is an example. They are available at most big box hardware and Ace hardware stores.
Push type PEX fittings
I also like the push/snap fittings
Just make sure PEX is cut clean, square and NO BURRS - I would not use crimps. I have previously used push type fittings in both plastic version and brass. I liked the plastic ones better. Here is an example. They are available at most big box hardware and Ace hardware stores.
Push type PEX fittings - HondavalkExplorer IIYou can get a pex pipe cutter for under 10 dollars. It will give you a nice square cut
- ScottGNomadSomething like a sharp box knife or razor blade work well and give the Pex a sharp, square edge. Best not to use anything that will crush it.
- pullin2ExplorerAaaahh! Thanks everyone. I'll pick up the crimp tool and rings from the hardware store today.
Is there a special tool needed to cut PEX? Or can I use my tin snips? - GordonThreeExplorerx2 different kind of plastic, not compatible with PVC "cement" ... there are solvent welding techniques and fittings for PEX but why bother?
Use the barbed hose-like fittings that easily attach with an inexpensive clamping system, or gasket sealed push-on fittings. - drsteveExplorerCan't glue PEX. Have to use either the crimp rings, or go with a Sharkbite fitting.
What are you trying to repair? - Bessie-HunterExplorerNo, it's PEX. You will need to use the right fittings and clamps. Or SharkBite fittings.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
