riggsp
Apr 24, 2014Explorer
I have a Boliy with the soldered in place battery cables...no problem!...they can be unsoldered with a heavy duty soldering iron (don't use a torch) then put new terminals on the wire ends to attach to your new battery...my battery tender came with clips and a separate 2 wire plug-in...I disconnected the battery wires at the other end (away from the battery) then threaded the plug end through the air vent on the side of the generator (next to the battery)...I just keep it plugged in when it's not being used, and the battery does fine.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
