desertfox06
Apr 28, 2014Explorer
riggsp wrote:
Not sure about your situation, but I'd guess there is a separate charging circuit for each battery...otherwise 1 battery would serve both purposes...check your owners manual for a wiring schematic to see if the batteries are connected, or disconnect 1 battery, and check to see if there is voltage present on the disconnected wires...if voltage is present, that means they are interconnected and one charger would work.
Thanks for the tip!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
