pbitschura's avatar
pbitschura
Burner tube assy. older Norcold Frig
Next project; disassemble and clean the burner tube on my Norcold Frig. It looks like two nuts and it should slide out.Is there some adjustment required to align the igniter and tube beyond comon sense? Recent events lead me to believe a cleaning is in order. It's a 1988 C.What say you about cleaning the flue? Any pointers would be useful.
  • Chris Bryant wrote:
    Officially, that old burner and tube are not available or replaceable. The new burner, orifice and tube from any 6 or 8 foot N series should work fine, though all must be replaced if you replace any of it, and the tube will have to be formed to fit.
    I may just settle for compressed air and a vacuum.
  • Officially, that old burner and tube are not available or replaceable. The new burner, orifice and tube from any 6 or 8 foot N series should work fine, though all must be replaced if you replace any of it, and the tube will have to be formed to fit.
  • Old-Biscuit wrote:
    pbitschura wrote:
    jplante4 wrote:
    Be prepared to replace the gas supply pipe. Mine was aluminum and there was no way to loosen the fittings without breaking the tubing.
    Good point. Is this still a stock part?
    What model fridge??
    I'm having trouble reading the tag, corrosion. I'll try to clean and magnify the id plate.
    What model fridge??
  • Be prepared to replace the gas supply pipe. Mine was aluminum and there was no way to loosen the fittings without breaking the tubing.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
