beemerphile1
Oct 23, 2013Explorer
ScottG wrote:beemerphile1 wrote:
If the hose has an inverted flare or a gasketed fitting you do NOT use any sealant at all, either Teflon or pipe dope.
The connection from the hose to the regulator is a standard one and needs either yellow Teflon tape or pipe-dope.
Mine is inverted flare and does not require a sealant.
http://www.campingworld.com/shopping/item/18-propane-acme-flexible-pigtail-hose/24035
http://www.easternmarine.com/pig-tail-propane-hose-connector-20-59073
The 1/4" inverted flare is very common.
