scottandgaye's avatar
scottandgaye
Cannot run A/C while at highway speeds
This is long and I am sorry for that. But describing the setup and problem is necessary.
Here is my situation. First of all, this is a 2005 Hitchhiker II 32.5 UKTG fifth wheel. I have built a generator enclosure for our two Honda EU2000i generators and it is mounted on the rear of the trailer using the 2" hitch. This enclosure is well ventilated with ultra-high CFM radiator fans. The generators are paralleled and their output runs to an auto-switchover relay for switching between shore and generator power. The generators in this specific test are set with the economy mode set to OFF (they are running wide open). This is required for running the air conditioner. The air conditioner is original equipment and is a RV Products (AIRXCEL) 8535B676 model. This is a 15K BTU AC with heat pump. With this setup, I am able to start and run the air conditioner when the vehicle is stationery. In fact, it will run all day, cycling on and off as necessary, to maintain the temperature setting in the trailer. However, when I take it out on the highway, within minutes, both generators have gone into their overload state. No breakers inside the trailer have tripped. This is my dilemma. So, here are the things I have done to try to isolate the problem:
1) I have run the generators at full throttle for over 8 hours while coming back from our last trip. All breakers in the trailer were ON, but the AC control panel on the wall was set to OFF. The generators ran all day with no issues. Average highway speed was about 65 mph.
2) I have run this very same setup with the AC ON while driving around town. Slower speeds (45 mph max), but many stops, starts and turns. No issues. The AC runs just fine and the generators never go into overload.
3) I have turned every breaker in the trailer to OFF except for the AC and turned the wall control to on. Temperature was set to 60 degrees on the thermostat so that it would stay on the entire test and not cycle. I then took the unit out on the highway for 15 minutes. When I stopped, the generators were into overload, but, again, no breakers were tripped.
Conclusions:
It appears that this problem is NOT related to the generators nor their installation. It also does NOT appear to be an issue with the combination of the AC and other system(s) on the trailer pulling too much current. The AC will run all day as long as I don't move the trailer. It seems as though there is something going on with this model AC (or perhaps this unit specifically) that is causing a very high current draw when the trailer is going down the highway. The compressor should not be affected by wind, so I can only assume that one of the fans is potentially the culprit. Either the internal blower that blows the air in the ducts is getting stalled by a buildup of pressure inside the trailer while moving or the fan that pull air over the coils is getting stalled.
Has anyone encountered a similar situation? I know many people with motorhomes run their on-board generator and AC all the time while on the road. This should be no different. If someone has specifics on where to look in troubleshooting this, I would greatly appreciate it.
The primary reason for wanted to run the AC while on the road is to cool the trailer (we live in Texas) before we actually pull off for the night. Otherwise, it can take 2-3 hours before it is actually cool enough to go to bed, especially in the summer.
Any and all help/suggestions are appreciated!
Oh, and I am an electrical engineer, so I do have some knowledge of what I speak. But this has me baffled! I hope someone on here with experience in a similar situation can help!
Regards,
Scott
Allen, TX
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
