skalashn's avatar
skalashn
Can't fix Honda eu2000i - please help!
I am trying to bring to life an old eu2000i. When I got the gen it was not in a good shape. It had been used in a marine environment some time ago and then stored with old gas in the system.
Here is what I have done so far:
- replaced fuel pump
- cleaned carb three times including running carb cleaner through everything and blowing with compressed air. I have also replaced all carb gaskets. The float bowl was rusted inside and I had to clean it with dremel steel brush.The carb looks sparkling clean
- cleaned spark arrestor of carbon
- washed fuel tank and filled with non-ethanol gas, added some seafoam.
THE PROBLEM: I can start the engine after 15-20 pulls but only with choke closed. It runs choked but very unstable, surging and usually dying after a few minutes. As soon as I open the choke it stops immediately.
What am I missing?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
