Gdetrailer
Apr 15, 2018Explorer III
pirlbeck wrote:
OK, I tested this antenna setup this afternoon. As my shop sits at the very bottom of a hill that blocks the direction (Des Moines) that the closest towers are at, I drove to the highest point in town. According to TVfool.com the closest towers are over 62 miles away. A scan picked up 14 OTA TV channels which only one of them was weak and pixelating. Given my distance I can live with that.
The FM radio reception seemed pretty good, but there was no AM at all, not even a very local station less then 15 miles away. Is there such a thing as an AM/FM splitter where I could leave the FM connected to the batwing and put a separate AM antenna up? Or anyone have recommendations for a good roof mount AM/FM antenna?
Thanks!
Yeah, I expected that FM might somewhat work and AM would not.
As far as a AM/FM antenna, simply choose one, not hard to do.
HERE is a quick search at Amazon..
Now, as a primer, short length antennas perform terrible, LONGER length antennas work MUCH BETTER.
Many short antennas tend to be the rubber ducky type (14" or so), longer ones look a lot like the old time auto mast types (20"-28")..
Stay away from so called "hidden" antennas which may be a simple foil or circuit board that you stick on a window, those perform terrible.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
