SDcampowneroper
Nov 14, 2013Explorer
StaJs wrote:
We had a soft area on our shower pan. Before it caused any problems I sprayed Great Stuff under there but first stuffed a garbage bag into the cavity then sprayed the foam into the bag. Should make it easy (not as bad anyway) to remove it if it ever needs it. Solid as a rock too.
Great idea to use a bag for the foam to support a good pan. I didnt think of that so long ago. What I was thinking of then was that with the foam stuck to the pan it would help seal the crack, & I thought that if the pan has to come out, I'd do it in small pieces anyway.
OP- Sounds like you are well on your way to a Good Job!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
