joraz's avatar
joraz
Cycling A/C Compressor
Any air conditioner experts out there? My dash air was operating just fine until a couple of days ago. Here's the deal. I start the rig and turn on the dash air. I can hear the compressor pull the engine down just a bit like usual. Soon, the air blowing from the vents begins to cool. Gets down to the high 50s (85 or 90 outside) and then cooling stops and the air warms. I watched the compressor and see it run at startup, however, after five or ten minutes the compressor starts cycling on and off, mostly off. It will run for 5 seconds, shut down for 45 seconds to a minute, run for 5 seconds and so on. The condensor fans are up front and I see they are running.
I don't have gauges but I do have a can of 134a and one of those cheapy hose/gauge deals. I hooked it up to the low pressure side and see around 40 when the compressor is running. Then it jumps way up to 90 or so when the compressor quits, back down when it starts and so onl
I need to take the rig in to check a brake and wheel bearing and I'll have them take a look at the A/C too. Anyone have an idea of what's going on? Thanks.
jor
  • If it gets to the hi 50's then the charge is not a factor. Low charge would cause short cycling at the beginning. I would suspect a BAD tstat. Jump the 2 wires on the Tstat (the tstat is at the Evaporator) and see if it stops cycling. Doug
  • MrWizard wrote:
    First
    Take a look under the front of the RV
    Find the evaporator and the big 12v fan, looks like trans cooler
    Make sure that fan is running
    2 yrs ago mine died and I had exactly the same symptoms, I
    When checking and testing I found the fan 25 amp fuse was bad, replacement blew as soon as I turned on the A/C
    Replaced the fan with new one from AutoZone, take the old one in when shopping for new one
    Condensor, NOT Evaporator. The OP states he has checked and it is running. Doug
  • If you have no airflow over the condenser like a bad fan or blocked by plastic bag or something, it could kick off due to high side pressure cutoff.
    Most likely its the low side pressure switch due to low charge or bad switch.....I had one fail once.
    This is all assuming you have a CCOT type.....cycling clutch orifice tube and not an expansion valve type.
  • First
  • Ivylog's avatar
    Ivylog
    Explorer III
    On a 95 Foretravel I would not worry about a leak if this is the first time in 4-5 years. Add 1/2 a can of 134 and see if it stops cycling. I use a IR temp gun on the condenser coils to see when 90% of them are hotter than the last one to judge how much more freon to put in. One can should be more than enough so do it yourself for $15 or have them do it for $100.
  • Short cycling is an indication it could be low on charge. But you really need to fix the leak before re-charging it.
