Fishinghat
Oct 10, 2015Explorer II
I second the recommendation to use 6 volt, deep cycle batteries. The larger cells will tolerate the discharge/recharge cycles much better than 12 volt batteries. You'll need at least two to produce 12 volts. Four would be better, but you may not have the room for that option.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
