Brandon327
Jun 20, 2014Explorer
Dometic ac not cycling properly
My ac unit is not cycling like it should. It will cut on when you first cut it on but them it will reach the temp you have it set at and cut off but then when the temp rises it may cut on and may not. Like right now I have it is set in 67 but room temp is 71 and it has not cut back on. Any ideas? They replaced the thermostat and control box about a month ago and it still is not working right.
