bfourman
Aug 04, 2017Explorer
Old-Biscuit wrote:
It didn't run on AC..that 30 seconds is time it took to check for AC power and then swap to gas cause NO AC available
Did you verify that the 120V AC outlet fridge power cord plugs into actually has AC Voltage>......plug a lamp in it, TEST it with voltmeter? Yes
Outlet Good....
Verify AC Voltage on board (J5/Hot J6/Neutral) Yes
Then need to check if AC Fuse ON circuit board has blown? Fuse good
(did you check that on 'other' circuit board before replacing?) Yes
Fuse blown......AC element bad
Fuse good.....check for AC voltage on J7/J8....leads to element (with fridge in AUTO and thermostat setting at MAX so cooling is called for)
No voltage on J7 & J8, checked as my assistant ran the fridge button.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
