rrobbins's avatar
rrobbins
Dometic Fridge too cold
In my 2000 Fleetwood Elkhorn the Dometic RM2453 fridge is getting too cold on gas and 120v. Haven't tried 12v. At the lowest setting it is still getting to about 32 degrees. This is right at the fins tho.
It does not have a thermistor which I can slide up or down. It has what appears to be a thermostat type sensor with a gas filled metal tube. I don't know of any other adjustments for the temperature. The past weekend it was ok as long as I didn't put my veggies up top but I am concerned in colder weather that I won't be able to keep it above freezing.
Any ideas? I can't find any info on how to test the thermostat.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
