diazr2
Mar 22, 2015Explorer
E-Z Flex ?
I am thinking about installing these on my fifth wheel does anyone out there have these in use, and if so what do you think of them.
N-Trouble wrote:falconman wrote:
Morryde also make a system. When I installed the EZ Flex on my TT I lost clearance because the stock equalizer was longer than the Ez Flex. I found out later that the Morryde system had one that would have fit better. It's been a few years so I'm not sure what's offered these days. Despite that it was a worthwhile upgrade.
When you say longer which dimension are you measuring to compare?
BFL13 wrote:You're mixing the message: yes, the metal bushings are much sturdier than the plastic ones. However, the "shackles" (links) are heavier so that they don't rip apart like the el cheapo ones installed by manufacturers. The holes on the OEM ones will keep elongating until the metal tears.
I did get that the shackles are heavier-built so won't wear through their metal vs plastic bushing holes as badly.
BFL13 wrote:All moving parts are wet and greasable. No need for confusion.
Nobody has explained how the other two holes get greased unless I missed it. Are they "wet" or not?
diazr2 wrote:Dexter states a minimum of 3". You need more clearance now. You may have gotten away with it so far, by not hitting a bumt that will induce maximum wheel travel.
Thanks for everyone's help. I do appreciate it. I think I am going to pass on these because of the clearance issues. I have already upgraded the tires to two sizes bigger than they were. My clearance on the wheel wells is about an 1½ so with that in mind and your great input I will save myself time and aggravation by skipping on these. Without your help I would have put them in and found out the hard way that I didn't have enough clearance. Thanks so much for the help
With Thanks Ray
