diazr2
Mar 22, 2015Explorer
E-Z Flex ?
I am thinking about installing these on my fifth wheel does anyone out there have these in use, and if so what do you think of them.
Padlin wrote:Yes, there are grease zerks on the equalizer/s. If you look at the photo on the first post you can see them.
I have the E-Z Flex but no wet bolts. Can't find anything in the Dexter Service Manuals for these, do I have to occasionally give them a shot of grease?
myredracer wrote:
That's what it was, thanks! How far beyond the hole should the figure 8 go?
Lynnmor wrote:
Don't put a groove in the bolt. That would create a stress point and a possible fracture. Instead, cut a figure 8 inside the bushing using a lathe or by hand using a Dremel type tool. It doesn't have to be real deep or pretty. Without a place to go, the hole in the bolt may be blocked and no grease will flow in. Some say to orient the hole on the side opposite the load but that wouldn't supply grease to where it's needed.
falconman wrote:
Morryde also make a system. When I installed the EZ Flex on my TT I lost clearance because the stock equalizer was longer than the Ez Flex. I found out later that the Morryde system had one that would have fit better. It's been a few years so I'm not sure what's offered these days. Despite that it was a worthwhile upgrade.
