Bill_Satellite
Oct 03, 2017Explorer II
Easy way to take 12V input and create 24V output
My coach has some 24V fans running with 12V power and I would like get them the full 24V they are rated at as there is also a speed controller I can use to control the speed and noise (Country Coach set it up this way to keep the sound down).
I have seen some setups online but don't really quite get it. I will have 1 12V input with a good size wire and it would need to output 24V (18-24V) so I can get some additional "blow" from the fans. The output will go to 3 squirrel cage type fans in my diesel heat (Webasto) fans. I have good access to the input and output wiring so if I can find the right device it should be pretty simple to setup. It's also in a fairly open cabinet so heat dissipation should not be an issue if these things create heat.
