landyacht318's avatar
landyacht318
Engine Computer Connector
My ECM has 2 connectors, a 14 way connector and a 60 way connector.
The 14 way connector was compromised by techs prior to, or early in my ownership, probing the wire insulation.
Eventually wires broke entirely and my 'temporary', get me home fix( 11 years ago) was to drill through the connector insert bare stranded wire through the socket connector so that it was sandwiched between pin on the circuit board and the socket on the connector, and reseat connector.
This temporary fix turned a bit permanent, and some other wires suffered the same fate and treatment over the years. Rtv'ing the probed wires had only slowed down the process. The upside was that everytime things went wrong with the engine I knew it was this dang connector acting up again.
The pressure required to reseat the connector with this extra copper in the pin/socket apparently has broken the solder joints on the potted circuit board. Right now I have to wiggle tweak push and pull to get everything working normally, then immobilize the connector in order to drive.
Today I drove to the junk yard and scored 2 connectors from 89 mopars in pretty good condition, but I believe 2 or more of the wires is a gauge or 2 thinner than what is on My Vehicle. Not sure yet, but the wire color coding is almost exactly the same.
Would be nice to just splice in a new connector without worrying about the possibly thinner gauge
The tail end of the connector is enclosed over the wire insulation.
Read: it is not going to be easy to get fatter wire attached directly to socket inside connector.
One of the fatter wires is for the field control of the alternator.
While similar to molex connectors they are not the same. The pins on the circuit board are not tapered. Inside the socket there is a little arm which puts pressure on the pin/socket.
I've a reman'd engine computer in the mail.
I'd love to never deal with this connection again. However it is in a bad area and prone to moisture intrusion and also bakes since it sits about 10 inches over the engine.
I'd love to just rtv over the dang thing, but that seems a bit permanent and drastic.
The locking mechanism on the connector is also a stupid design and does not really hold it tight or even moisture tight unless huge amounts of dielectric grease are gobbed on.
But I d rather not have grease inside the pin and sockets, but just outside this zone.
Splicing the new connector in is going to be a bit tight. Sure be easier to use uninsulated crimps and quality heat shrink rather than soldering.
Any tips and tricks I am unaware of to make this a permanent solution to a decade long issue?
Also I am looking to have my old ECM rebuilt to have as a back up. Anybody have any recommendations on companies who do such things? Besides Cardone?
Would be great if I could get them to add an adjustable trim pot for the voltage regulator ;)
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
