j-d's avatar
j-d
Explorer II
Apr 04, 2017
Erratic Kwikee Steps
This is a two-step assembly on a 2003 Class C. It's worked fine for years. A few years ago, I had to lubricate it since it was binding when closing. Till Today...
We broke camp, and the step operated normally, opening and closing when the door opened and closed with the coach engine running. It was normal for a number of in/out cycles at the campsite and again at the dump station.
As we left the campground, we heard the step motor running, and could see the step extending and retracting on the road, with coach door closed and locked.
We stopped and noticed that sometimes the step would run partway in and out, from a nearly closed position. I'm glad it rained a lot in Chattahoochee FL yesterday and dried this morning. Didn't get dirty crawling under and removing two 5A fuses. Steps stayed up.
At home, put the fuses back and started trying the door with the engine off and step switch on. Step doesn't operate, and seems stuck toward the closed position.
Any ideas? I first thought it was the door reed switch, but that wouldn't explain it seeming jammed. I spray lubed it with no change. Wondering if something jumped time in the motor/gearbox...
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
